Inventor Forum
How to create this geometry?
15 REPLIES 15
Message 1 of 16
drawingsCHR7R
847 Views, 15 Replies
Hi guys,
Attached is an image of locking 'teeth' that I want to try and recreate, I have tried doing a profile with a 3D sketch to get the path but my attempts thus far have not been all the successful, could someone please assist me in this so that I may learn how to do this better going forward.
Thanks!
15 REPLIES 15
Message 2 of 16
aurel_e
in reply to: drawingsCHR7R
My attempt attached (Inventor 2019)
Message 3 of 16
drawingsCHR7R
in reply to: aurel_e
How would one do this in an ipt? Because the part I am doing is actually a casted part and not a sheet metal?
Great attempt though!
Message 4 of 16
aurel_e
"Bend part" does work with the extruded part as well. Doesn't have to be a sheet metal plate. You can also use "Convert to part" and add other features.
Message 5 of 16
JDMather
What version of Inventor are you using?
Can you Attach the *.ipt file of what you have so far?
Message 6 of 16
drawingsCHR7R
I am not too familiar with how that would work on the current piece that i am doing, attached is the part I want to make those 'teeth' on. Would you be able to show me how it is done on this piece?
Message 7 of 16
drawingsCHR7R
in reply to: JDMather
Hi JD,
I am using IV2021,
attached is the part.
Message 8 of 16
Hi guys,
Took some time but I found a result that I am happy with.
If anyone has a suggestion for a better workflow I would love to hear it.
Message 9 of 16
freesbee
(sorry, I cannot try it because I do not have a 2021 or a 2020.3 under my hands now)
From your picture it looks like a coil feature. Or maybe I've missed anything?
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
Message 10 of 16
drawingsCHR7R
in reply to: freesbee
Hi there,
it is not a coil feature, it is a locking mechanism of sorts that prevents the part that sits on top of it from rotating in a certain direction using 'teeth'.
Message 11 of 16
freesbee
...sorry, I was in a hurry and I probably expressed myself wrongly.
I understood that it is a locking mechanism using those teeth to prevent release. My suggestion was to use the inventor coil feature to model that shape. I have done the same in this part (it's a special safety washer that I have authored in a content center), which also has some similar teeth preventing release (even if the real part is much more complicated). They were done with a coil feature, and they look very similar to the picture you have posted (again, maybe I misunderstood).
I hope it helps 
Massimo Frison
Message 12 of 16
drawingsCHR7R
Ahh, I see. Yes I actually ended up using the coil feature to get what I wanted, it worked perfectly!
Message 13 of 16
freesbee
...sorry, I have to correct myself once again. In this specific washer I have used a revolution (one can tell it from the shape of the short edge of the teeth), but for the shape of the teeth from your picture, the coil is better.
Massimo Frison
Message 14 of 16
drawingsCHR7R
Agreed, could i see the part file where you used revolution by any chance?
Message 15 of 16
freesbee
Here it is.
I've used some math to keep it under control: I didn't want too many geometries but still a decent representation of the component.
Massimo Frison
Message 16 of 16
drawingsCHR7R
Thanks a lot! Appreciate all the help.
