how to create the profile tooth octoide and spherical bevel gear
hello
how to create the profile tooth octoide and spherical the bevel gear
how to calculate thickness the tooth bevel gear
Cadmanto
Welcome to the forum.
Not really sure what that looks like.  Posting an image would be helpful.  Have you tried going to the website of the manufacturer of these gears to see if they have available models to download?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! Have you tried using Design Accelerator -> Power Transmission -> Bevel Gears. If I understood you requirement, it seems more like customized. You might need to create the Bevel Gears using Design Accelerator and then tweak the geometry using modeling features.
Thanks!
Software Test Engineer
thanks
how to calculate this equation ?
WHolzwarth
Hmm, Johnson.
Bevel gear calculation needs improvement. By definition, all rays along the gears of straight setups need to be in the intersection point of both gear axes.
Smiley Frustrated But that's not the case with Inventor's bevel gear generator.
Walter
Walter Holzwarth
