Hi can please help me how to create core like attached image. it is in some angle
@Anonymous
I would do it like this way,
1. Circular profile on xy plane
2. Oval/Capsule-shape at 90° angled plane from xy with
3. from the side view you may take that guide curves.
even after that some more tricks could be performed to get it in correct shape
What version of Inventor?
Attach the *.ipt file of your attempt here.
Where is the view for Section D-D?
Are you going to Attach the *.ipt file of your attempt?
Hi! Please share your attempt here. We need to know where you got stuck.
Many thanks!
@Anonymous wrote:
Can you please share .ipt file
My solution is rather complex and first I need to determine your experience level with Inventor.
You ipt attempt will give me an idea of how much work would be required in explaining my solution (which I have not entirely completed yet - still several hours of work to completion).
Just bumping this one back to the top - I forgot all about it when there wasn't a file Attached to the initial post.
I wish I had had this file before I spent hours on my attempt.
I have some other work to get done - so it will be a while till I can compare this mode to my attempt.
