How to convert part to Standard part
Message 1 of 8
Hi everyone,
I would like to convert a normal part to a standard part (like the library files) so that when they are represented and cut in a drawing they remain as a solid, without being cut, as happens with the parts that are inserted from the content centre.
The parts that I want to convert are screws that I have taken from the content centre but I have designed them in a file with iPart so that it is easier to insert them and also have our company code.
Thanks.
Replies (7)
Message 2 of 8
tyas.swinnen
I think you are looking for following checkbox: Document Settings > Modeling > "Participate in Assembly and Drawing Sections'2021-02-08 14_15_50-Window.png
Message 3 of 8
mcgyvr
You can control section view participation in Document Settings..Modeling tab or right in the drawing itself via the right click menu on a part by part basis.
I'm really not sure what "Normal" vs" Standard" means to you.. Do you mean "normal" vs "content center" parts? A "library" part is simply a normal part saved in a designated library folder that prevents you from modifying it without permissions to write to that library location.
You can easily "Save Copy As" parts from the content center into a non-library or library folder to remove them from content center and use them just like "normal/standard?" parts.. Just save them in an appropriate folder.
Message 4 of 8
@tyas.swinnen
Thanks for your reply but this is not working.
I checked it in another parts in which this option was selected but they are also cut in the drawing.
Message 5 of 8
@mcgyvr
Standard means the parts which are in the concent center, like screws or nuts, for example.
"You can easily "Save Copy As" parts from the content center into a non-library or library folder to remove them from content center and use them just like "normal/standard?" parts.. Just save them in an appropriate folder."
This is what I did. I saved as the screw and created an iPart with all the types we use.
But when I place it in a drawing and cut it, it does, when a Standard part taken from the centre of content does not.
I only saved as the screw and created an iPart, that's why I don't understand why inventor is using it like a Normal part (designed by me).
Hope you understand my unquiry better.
Many thanks.
Message 6 of 8
tyas.swinnen
Did you test it in the master iPart and/or in the child part?
Message 7 of 8
I modified the master part as you showed me, and then I deleted and generated all the files again.
I replaced it in the assembly, placing the master and selecting the child.
Then I reaplaced the assembly in the drawing and doesn't works.
I don't know if I'm doing something wrong 😞
Thanks @tyas.swinnen
Message 8 of 8
johnsonshiue
Hi! Maybe in the drawing view, the components are set to be cut. Go to Tools -> App Options -> Drawing -> Section Standard Parts. Set it to "Never."
For existing sectioned views, you will need to right-click on the component nodes under the view node in the browser -> Section Participation -> change it accordingly.
Many thanks!
Software Test Engineer
