how to convert part file to shett metal
huseyinagtas
huseyinagtas
how to convert part file to sheetmetall
JDMather
Your part is not uniform Thickness?
You part does not have any Bends?
The sheet metal rule Thickness does not match the part thickness?
I had to break the link to the original since you did not attach it here with the Derived Component.
huseyinagtas
Should I follow the same path for this file?
JDMather
Attach your attempt to convert this to sheet metal.
