Your part is not uniform Thickness?
You part does not have any Bends?
The sheet metal rule Thickness does not match the part thickness?
I had to break the link to the original since you did not attach it here with the Derived Component.
Should I follow the same path for this file?
Attach your attempt to convert this to sheet metal.
