How to Convert Normal dimension into Driven Dimension using iLogic?
jeeva.scientist
jeeva.scientist
I have done it by using three different rules. But I want it to be done using just one rule. Please take a look at the below link. Thanks for your time,
https://forums.autodesk.com/t5/inventor-customization/how-to-convert-normal-dimension-into-driven-di...
Sergio.D.Suárez
Hi, sorry I had not seen that message in the other thread.
Try the following rule. I think it could work
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch = oCD.Sketches.Item(1)
Dim oDim As DimensionConstraint
For Each oDim In oSketch.DimensionConstraints
    If oDim.Parameter.Name = "d1" Then oDim.Driven = True
	If oDim.Parameter.Name = "d0" Then oDim.Driven = False
Next
'd0 = d1 * 2
oCD.parameters("d0").value = oCD.parameters("d1").value *2
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
    If oDim.Parameter.Name = "d0" Then oDim.Driven = True
	If oDim.Parameter.Name = "d1" Then oDim.Driven = False
Next
 I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
jeeva.scientist
Thank you very much @Sergio.D.Suárez
Working Proof,
