How to Convert Normal dimension into Driven Dimension using iLogic?
jeeva.scientist
Message 1 of 9
jeeva.scientist
I want to convert "normal dimension" into the "driven dimension" & vice versa using iLogic Code.
if I have so many dimension how to I pick a specific dimension to convert.
I want to convert the,
  • d0 into Driven Dimension
  • d1 into Normal Dimension
Replies (8)
Message 2 of 9
JelteDeJong
try running this iLogic rule and select a dimension.
Dim dimension As DimensionConstraint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter, "Select dimension")
If dimension.Driven Then
	dimension.Driven = False
Else
	dimension.Driven = True
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 9
jeeva.scientist
The code you gave works perfectly ( Working Proof  ), Thanks. It is not what I expected.
I sorry I did not explain my problem clearly let me explain clearly.
I don't want to pick the dimension with the mouse.
for example,
I have four dimensions,
  1. d0 (normal dimension)
  2. d1 (driven dimension)
  3. d2 (normal dimension)
  4. d3 (normal dimension)
I just want to change,
  • d0 > driven dimension
  • d1 > normal dimension
  • d1 = d1 + (d0/2)
  • d0 > normal dimension
  • d1 > driven dimension
Message 4 of 9
HideoYamada
When the sketch is activated, You can access to the dimensions from :
ThisApplication.ActiveEditDocument.ActivatedObject.DimensionConstraints
Here ThisApplication.ActiveEditDocument.ActivatedObject is activated PlanarSketch object.
If the sketch is not activated, you must specify the sketch to edit.
For example,
Set dcs = ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches(sketchNumber).DimensionConstraint
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 5 of 9
Sergio.D.Suárez
Hello, here I show you an example of how to achieve what you want in a sketch identified as the first through the item.
Sub Convert_DimA()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCD As ComponentDefinition
    Set oCD = oDoc.ComponentDefinition
    Dim oSketch As PlanarSketch
    Set oSketch = oCD.Sketches.Item(1)
    Dim oDim As DimensionConstraint
    For Each oDim In oSketch.DimensionConstraints
        If oDim.Parameter.Name = "d0" Then   ' Indicate the name of the parameter you want to do in the driven dimension
            oDim.Driven = True
    Next
End Sub
Sub Convert_DimB()
        If oDim.Parameter.Name = "d0" Then  ' Indicate the name of the parameter you want to do not in the driven dimension
            oDim.Driven = False
    Next
End Sub
I hope this helps you to develop your code completely. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 6 of 9
jeeva.scientist
Hello, thanks for your code. I made some change to suit my application. hear I attached a video, in that video, I have shown my requirement. But I did that in a long way.
I have used three separate rules to get what I need. is there a way to use just one rule to combine all three operations.
steps are,
  • Enter a new value for "d1" ( when -> "d0" is driven dim & "d1" is normal dim ),now the "d0" value is driven by the "d1" value.
  • In Rule0 > it converts "d1" to driven dim & "d0" to normal dim
  • In Rule2 > it execute a expression (d0 = d1 * 2) 'for the new value of "d1"
  • In Rule1 > it converts "d0" to driven dim & "d1" to normal dim  (reverse of Rule0, to bring it to original state)
Rule0:
        If oDim.Parameter.Name = "d1" Then   ' Indicate the name of the parameter you want to do in the driven dimension
            oDim.Driven = True
    Next
            oDim.Driven = False
    Next
Rule2:
	d0 = d1 * 2
	InventorVb.DocumentUpdate()
	iLogicVb.UpdateWhenDone = True
Rule1:
            oDim.Driven = True
    Next
        If oDim.Parameter.Name = "d1" Then  ' Indicate the name of the parameter you want to do not in the driven dimension
            oDim.Driven = False
    Next
Edit form:
Thanks for your support.
Message 7 of 9
jeeva.scientist
Please a look at Message 6
I have used 3 different rules to make it work.
I want to do it with just one rule.
thanks.
Message 8 of 9
jeeva.scientist
This question has been solved by @Sergio.D.Suárez  in the other post please follow the link below.
https://forums.autodesk.com/t5/inventor-forum/how-to-convert-normal-dimension-into-driven-dimension-...
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch = oCD.Sketches.Item(1)
    If oDim.Parameter.Name = "d1" Then oDim.Driven = True
	If oDim.Parameter.Name = "d0" Then oDim.Driven = False
Next
'd0 = d1 * 2
oCD.parameters("d0").value = oCD.parameters("d1").value *2
    If oDim.Parameter.Name = "d0" Then oDim.Driven = True
	If oDim.Parameter.Name = "d1" Then oDim.Driven = False
Next
Working proof
Message 9 of 9
marianYKR2R
jeeva.scientist. Thank you very much. This is what I was looking for. Regards
