How to connect rectangle to cylinder (easily)?
j.pavlicek
Message 1 of 10
j.pavlicek
I wonder if there is some easy way how connect revolved and extruded body both created from cross-section sketch.
My current approach:
But it tends me to create sketch every time. Is there some function which extrude face in direction of its normal vector "To Next"?
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Replies (9)
Message 2 of 10
admaiora
You can use Direct Edit
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 10
-niels-
@admaiora for some reason that didn't seem to work for me when the rectangle is tangent to the cylinder.
(it works when there is an offset)
@j.pavlicek instead of projecting each line separately you could use "project cut edges" to get them all at once then you can extrude the desired profile "to next".
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 4 of 10
admaiora
Yes. You are right.
Admaiora
Message 5 of 10
IgorMir
Yes, it works.
You need to specify the face twice. (From both sides of the tangent line). Here is a Part1 in IV2020 format.
Cheers,
Igor.
P.S. Yet if the object edited is in a shape of an I-Beam - I too have a problem with direct editing of it. Part2 is showing the issue. But, with all honesty - I would do the design differently anyway.
Cheers,
Igor.
Web: www.meqc.com.au
Message 6 of 10
JDMather
@j.pavlicek wrote:
I wonder if there is some easy way ...
Attach your *.ipt file here.
Message 7 of 10
-niels-
@IgorMir
@IgorMir wrote:
Yes, it works.
I tested it a bit more, it doesn't work in IV2018, but in IV2021 you have an extra option that makes it possible:
Turning off "automatic blending" made it work. (guess this is available from IV2020 onward, not sure about IV2019)
A screenshot to show IV2018 doesn't have that option:
Niels van der Veer
The Netherlands
Message 8 of 10
IgorMir
Hi Niels;
Thanks for looking into it. For me, personally - that model is pure a curiosity one. As I had said before - I wouldn't have modeled the item that way anyway. But, since we are in this discussion - here is a Part2 in IV2020 format.
In here the adjoining members are I-Beams. And if it is tangential to the round body - the Direct edit fails. Deselecting "Automatic Blending" option makes things even worth.
Yet, as I have said before - if the adjoining part is just a simple rectangle - the Direct Edit works as expected.
I believe -  guys at the Inventor developing team might want to have a look at it.
Cheers,
Igor.
@-niels- wrote:
@IgorMir
@IgorMir wrote:
Yes, it works.
Message 9 of 10
-niels-
@IgorMir Tried your part and can confirm that an i-beam profile acts worse indeed:
Also agree that this might be interesting for @johnsonshiue and the Inventor team to look at in regards to the direct edit functionality.
(as there are many ways to model this so it works)
Niels van der Veer
The Netherlands
Message 10 of 10
admaiora
@-niels-  no.. (I was thinking the same..)
that option just turn of the face adaption.
If you have a cylender with an axial  hole..doesn't work.
Admaiora
