How do I explain this, I have Inventor 2021 at my new job. All the other versions I have used had a differant layout to the ribbon. For some reason unlike 2024 when starting a new model accross the top you have to select 2d drawing then select from drop down. Or under wire frame go to the create tab and then drop down. How in the world can I get rid of the drop down feature? All of the other versions it seamed like less up and down to select features. Hope this makes sense to someone.
