How to change drawing style outline for part
jcasey7460
Message 1 of 9
jcasey7460
....when placing a base view in my drawing, the base view shows the outline of the drawing in black (that's what I want to keep). But when I create a projected view it turns the outline of the drawing to a white color. How do I keep it all black? I assume this is under the styles editor, if so where? Under the the Styles Editor => Layers? If so, which one? Or am I looking in the wrong place?
I know about the Document > Tools > Sheet, that's how I changed my  background to blue. But it only lets me change the background and outline...
Note, I'm having a tough time with the terminology so I attached/uploaded a video to explain what part of the style I am trying to change/keep.
Replies (8)
Message 2 of 9
jcasey7460
Also, I see that if you choose Select Part Priority from the quick access menu, then right-click, select Properties. You have a dialog box called Component Properties. Changing the layer color on the part level/layer does what I need. But of course, you have to do that every time so that's not usable...and I am not seeing a Component layer in the Styles editor so still looking for whatever style controls the part color, globally or for the entire drawing...FWIW, I know how to create my own styles so I don't screw up the default layers. 😛
Message 3 of 9
jcasey7460
...just noticed that when I change the color of the sheet in Tools > Document Settings > Sheet tab > Colors > Sheet to a darker color it changes the "text" from black to white.
Where do you change this behavior at? I am not seeing it in the style editor.
Message 4 of 9
CGBenner
@jcasey7460
Hi, Maybe you posted this and I missed it, but what version of Inventor is this?  Is it 2021 with Dark Mode enabled?
If yes, go to Application Options and the Colors tab.  Under "In-canvas Color Schemes" is a Customize button.  Maybe what you are looking for is in there somewhere, depending on what scheme you're using.
Chris Benner
Message 5 of 9
imajar
Wow, just did some experimenting - that definitely has alot of problems!
I can see that inventor is somehow automatically changing some colors, I can not see anyway to control what it is doing.  Things seem to print OK, but saving to PDF picks up the problems shown on the screen (for me anyway).  Some lines types do change, others dont, some words do change, others don't - for example, my note text stays black (not visible against a black screen), but my template text does change.  @johnsonshiue, could you weigh in on this one?
My recommendation would be to keep the default sheet color.  (if you are trying to go easy on the eyes, I was able to change it to a lighter grey that didn't mess with anything.)
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Message 6 of 9
jcasey7460
Good idea, I think it's best to stick with default and just tweak the colors a bit. What I think I'll do is experiment with the darkest color I can get before it turns to white. 🙂
Message 7 of 9
johnsonshiue
Hi Folks,
This does look like a bug to me. I cannot explain the behavior. It seems that the view edges color can no longer go back to By Layer after it was to something else. The only way to regain the By Layer color was to recreate the view.
I need to work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 8 of 9
LishuangLu
@jcasey7460 , thanks for reporting! There's indeed some intellegency in this area which is to make the view or annotations are still visible after changing the sheet color into some other color. If we don't provide this way, users will not see anything easily by default. However there may be some issues in the automtically handling. Like the ones reported by you, we will try to reproduce locally and make the fix during our defect fixing week.
For the issue mentioned by you “when I create a projected view it turns the outline of the drawing to a white color.”, I could not reproduce from scratch in my side yet. What I reproduce is drawing views will not update edge color when change the sheet color, eg. create 1 shaded base view and 1 projected view
  1. Change the sheet color into black
  2. The two views are still showing black edges
  3. If do some edit, then undo the edit, the above two views will show white edges, so expect the two views in above steps can show white color. Please let me know if you have other suggestions.
As for the view color control, this actually can be adjusted from Style and Standard Editor -> Layer, the Visible (ISO) is used for controlling the view edge color. Please have a try and let me know whether it works for you.
Thanks for your support as always!
-Lisa
Message 9 of 9
jcasey7460
@LishuangLu Nice. The Style > Standard Editor -> Layer, Visible seems to solve the my issue so I'm happy. 🙂 Thank you!
