How to change Assembly origin to a specific origin part?
e.gualterdossantos
e.gualterdossantos
I have an assembly model, and the position is off to the "Origin". I am looking to define the "Origin" Planes to the part or move the assembly to the origin location. Any suggestion?
IgorMir
I would have a look at the first grounded part to start with. How is it placed into the assembly in relation to the Assembly Origin? Unground it (and the second grounded part too). Using constrains - align the first part the way you want. And continue from there.
Cheers,
Igor.
Web: www.meqc.com.au
Sam10001
If all the parts are constrained together you can unground the first two parts and constrain the assembly to the origin planes. But that looks like an imported file that would have no constraints. You could either constrain each part properly or you could insert this assembly into the fresh assembly and constrain that to the origin planes. Or insert a UCS or workplanes and refer to those as the 'origin'.
e.gualterdossantos
I solved the issue. I had some missing constraints, and then I used "Grounded and Root": https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-98FA88B2-AA32-4A27-946A-DCECB36A6696
Thank you all
Najib_miguil
Community Visitor
Community Visitor
thamk you very much, i had same issue , juste resolve it following the link you shared.
