How to adjust the appearance (size) of the projection of this part and its dimensions' size and how to put the quantity in the tabe?
mech.eng.ahmedmansour
Hello, I cannot show the projection the best way in the pdf, it is not clear. I need somebody who can help me exporting this part into a pdf the best way having the quantity and the right size of the dimensions and the lines of the projection. I cannnot see the projection lines in the pdf.
blandb
You will also need to post the part itself.
Autodesk Certified Professional
CGBenner
@mech.eng.ahmedmansour
It is unclear exactly what details you are trying to show and dimension, but you could use a Detail view to enlarge an area of the part that needs to be seen better, and then add some dimensions there.  Once the drawing is sent to PDF, it is too late.  Anything you do will need to be done in the idw/dwg.
Chris Benner
Thank you! It works! Now how do we add the quantities of the part to the table?
Thank you!
CGBenner
Since your drawing is of a single part, you can either manually override the text in your parts list for the quantity you need made, or simply add a text note on the sheet, for example:  (3) PIECES REQ'D
If you have this part represented in an assembly, and create a drawing of the assembly, the quantity will automatically reflect the number of instances in that assembly.
Chris Benner
