How the setting of surface is saved
I need to know, how the settings of surface are saved in .ipt. When I change the surface, e.g. from red to blue, the Inventor must have saved it somewhere - because when the .ipt is reopened, the change still persist. I thought, this should be in iProperties, but I didn't found it anywhere there.
The point is, that I'm making new item in ContentCentre and I want to make it with specific surface (the user will have the option, between more surfaces to choose) and I haven't found, in which property can I define it.
Thank you,
Adam
Xun.Zhang
Hi Adam,
I am sure you are talking about object property, for example, you can select a face and navigate to property from context menu, you will find the appearance definition.
In your case, yes, the properties are well-saved and defined in the file but you can leverage iLogic or VBA to read or write the property.
As for Content center, you can have a try, but I doubt that only part level appearance is one key to be set for CC during publishing.
Hope it helps!
Xun
Ok, thank for your answer. I will choose another solution to this issue.
