12:27 AM
- Mute
- Permalink
- Report
I need to know, how the settings of surface are saved in .ipt. When I change the surface, e.g. from red to blue, the Inventor must have saved it somewhere - because when the .ipt is reopened, the change still persist. I thought, this should be in iProperties, but I didn't found it anywhere there.
The point is, that I'm making new item in ContentCentre and I want to make it with specific surface (the user will have the option, between more surfaces to choose) and I haven't found, in which property can I define it.
Thank you,
Adam
