Inventor Forum
How I can set the "Unit" for the tool "Add Assembly" or the template.
1 REPLY 1
204Е10
331 Views, 1 Reply
Usually I like to use the tool Add Assembly on the Productivity, my problem is that I need to set the unit to mm because the default template its use is with "cm" how you can see in the image attached. How I can change this template or at less set the units?
Cheers.
1 REPLY 1
JDMather
in reply to: 204Е10
I didn't test this out since you didn't Attach any example files, but have you Configured your Default Templates?
Technology Administrators
