Inventor Forum
Welcome to Autodeskโ€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
How fast is your Inventor PC really?
2,218 REPLIES 2,218
Message 1 of 2,219
Raider_71
270844 Views, 2218 Replies
Hi guys,
We have had to do some testing on a bunch of Inventor PC's recently to determine which of the PC's needs to be replaced. Obviously we needed to find out which of the PC's are the worst eprformers as there was only budget to replace 50% of the design PC's. So we thought the Darwin theory will come in handy right... ๐Ÿ™‚
Anyways I started searching on the net for toppics on how to benchmark an Inventor PC. Then I thought whats the point of using gaming benchmark tools because Inventor is not a game and there are more aspects than just graphics performance when it comes to percieved performance on an Inventor PC right.
So we decided to create our own Inventor benchmark tool which tests various aspects of an Inventor PC to give us an overview of our PC's performance. This then helped us make a decision as to whcih pc's to replace.
We have made the tool available free of charge to anyone interested in checking how their PC stacks up to their peers or friends. ๐Ÿ™‚
Please download it here and post your results here as well if you want. Would be interesting to see what beast workstations are out there.
I would like to say thanks to Kirk #karthur1, for helping in testing the app.
Please feel free to send any suggestions our way. There is an email link in the app.
Download and Install
The application will work with Inventor 2014 to 2016 only.
IMPORTANT: After installation there will be an Inventor Bench icon on your desktop that looks like this: 32x32.png
My resluts:
HP Elitebook 8560w with an SSD upgrade.
2,218 REPLIES 2,218
Message 421 of 2,219
@machiel.veldkamp wrote:
Really this thread is gold
An appropriate description considering how many people have went out and spent money as a result of this thread haha
Message 422 of 2,219
in reply to: Neil_Cross
I have been following this thread and it is really interesting. So @Neil_Cross your saying that the operating system which you are running could also have an impact upon what score you get on the Bench mark.
Message 423 of 2,219
Neil_Cross
It would appear so.  However, in my cheap system build I went for an AMD graphics card and honestly it wouldn't surprise me if it was some kind of weird AMD thing.  I've got 2 NVIDIA cards here though and 2 AMD cards, so I can test almost every scenario.
But yea I've put Windows 10 back on, ran the test again, I'm getting 300% increase in visual performance.
Another thing I've noticed is that Windows 10 passively consumes a lot more video card RAM than Windows 7.  This is all stuff I'll be investigating further though.
Message 424 of 2,219
@Neil_Cross We did the test again with a complete restart and only opened Inventor to run the bench.  We watched the CPU utilization and the GPU utilization.  The bench completely spikes one core of one CPU.  GPU utilization from Process Explorer stays around 38%.  When drawing the "A" the screen stutters a little.  We use Autodesk ETO which requires us to have defer updates on.  Changing this didn't appear to make a difference however.  We are going to do some additional testing with 2016 to see if this helps with the CPU utilization.
Message 425 of 2,219
pball
in reply to: Raider_71
Finally got around to overclocking my new personal computer after some delays. Here is the stock score and the 4.3ghz overclock score. I'm a little confused why the graphics scores are a little lower with my overclock as I did nothing with my graphics card, since that hurt my score some.
3.3ghz Stock
4.3ghz Overclock
Message 426 of 2,219
Raider_71
in reply to: pball
Hi @pball,
Did you run a Quick tests or extensive tests?
P
Message 427 of 2,219
Neil_Cross
@Raider_71 There's something extremely funky weird about the test part (the VGA one) that the bench tool uses.  When the bench tool runs the graphics test, on Windows 7 I'm seeing a result of around 45Hz, the EXACT same computer with Windows 10 runs that test at 160-170Hz.
Windows 7
Windows 10
The two results above are from the exact same system, it has a dual boot setup off the same SSD, so basically both tests are utilising the exact same hardware in every respect.  The version of Inventor is identical, the application settings are identical, graphics driver is identical, but look at the graphics scores.
Originally I thought it could have been Windows 10 handling the engine differently, but manually observing the frame rates on other models shows that this isn't doesn't appear to be the case, it seems to be an isolated issue with the part provided in the bench tool.  If that's the case, which I'm by no means saying it is as I still can't explain the above, but there's a potential chance that people running Windows 7 are seeing an artificially low score?
FYI the above is the score from the ยฃ400 / 500 Euro / $570 budget giant slayer system I've built.
Message 428 of 2,219
pball
@Raider_71
I've been running the 3 cycle test since it was introduced. I'll try running it again after a restart, that was right after I finished overclocking that pc. So I had some diagnostic stuff running in the background.
@Neil_Cross
That budget build beats out my work computer. I really hope I can get our IT guy to build new systems following the finding of this thread.
Message 429 of 2,219
Neil_Cross
in reply to: pball
@pball That was my plan, I bought and built this budget PC just to run this bench tool.  My plan was to pick the right parts for an Inventor build, and beat PC's that cost 10 times as much as this, I think I've done that.  I wouldn't ever recommend that someone buys this very spec for work, that wasn't the point, the point was to prove that you don't need to spend the equivalent of Greece's national financial deficit to get a PC which performs.  It's all about being wise with the choices you make.
Message 430 of 2,219
So far; CPU and fast storage seem to be the two most important thin, no?
___________________________
Message 431 of 2,219
Raider_71
Hi @Neil_Cross,
Thats quite strange! I am not sure why that would be the case as the part used for both tests (Win 7 and Win 10) would be the same as Inventor used on both is the same.
I will give it some thought.
Message 432 of 2,219
It's all about the CPU, the SSD makes a massive difference as well, but there's no benefit in having a PCIe NVME drive over a SATA3 drive for example, although the PCIe drive can physically write to the disk 3-4 times faster than the SATA3 drive you don't see that in Inventor, the rate in which Inventor writes to the disk is bottlenecked by other factors.  But with that said you'd still want to go for the fastest drive as other programs could benefit from the things that Inventor doesn't.
Message 433 of 2,219
Neil_Cross
@Raider_71Strange indeed, it's not a one off either.  I've formatted and rebuilt this PC several times now and it's been consistently like that across each rebuild.  But then when I open up something else, an assembly for example, I don't see the frame rate differences across Win 7 & 10.
Message 434 of 2,219
This was awesome because co-worker and I got to compare performance on near identical machines.
kelly.young has embedded your image for clarity.
Message 435 of 2,219
Neil_Cross
So here's the results of my budget build, giant slayer, not at all cheesy.  Full spec and prices.
CPU: Intel Pentium Dual Core G3258 3.2GHz Socket 1150 3MB L3 Cache Retail Boxed Processor | ยฃ44.15 | $65 |
Mobo: Asus H81M-PLUS Socket 1150 DVI HDMI 8-Channel HD Audio mATX Motherboard | ยฃ38.32 | $55 |
Case: Thermaltake Core V21 Matx Mesh Stackable Case With 200MM Fan | ยฃ36.65 | $60 |
HDD: Crucial BX200 240GB 2.5 inch SSD | ยฃ47.49 | $65 |
PSU: Coolermaster GM-Series 550W Semi Modular 80+ Bronze Power Supply | ยฃ33.74 | $50 |
GPU: MSI Radeon R9 380 Gaming 2GB GDDR5 Dual-Link DVI-D HDMI DisplayPort PCI-E Graphics Card | ยฃ134.15 | $210 |
RAM: Crucial Sport BLS8G3D1609DS1S00CEU 8GB Ballistix 240-pin DIMM DDR3 PC3-12800 memory module | ยฃ23.32 | $35 |
Total System Cost = ยฃ360 exc VAT // or // $540 all in.
The winner here is the Pentium G3258.  That CPU was built and sold by Intel on it's overclocking strength, you're actively encouraged to overclock this chip.  As a result, people are reporting safe and stable overclocks at 4.7-4.8GHz.  However the silicon lottery wasn't good to me, I couldn't hold it past 4.2GHz.  If I had received a good chip, I think the score could have easily been over 10+.  This is all done on the stock cooler and temps rarely went over 70c.
If I was buying for a business, I would never recommend this build however the purpose was to highlight the fact that if you pick the right spec, you don't need to spend a fortune.  I see far too many people paying thousands for wrongly specified computers, thinking they're going to be adequate because there's a Xeon/Quadro/Precision/Z Workstation/Precision badge on the box.  One poorly chosen component can handicap a system which costs thousands.
I'm chuffed to bits with the score.  It was never going to top the tables, but looking back through the results, it's beaten the majority of computers excluding the Skylake (6XXX) and Devils Canyon (4790K) CPU builds.  This system was a fresh build of Windows, no AV, no third party applications i.e. Office etc, does that make this a fair test? Who knows, but the results are the results.
Hope this helps, it was a fun experiment!
Message 436 of 2,219
Aw man! I just upgraded my PC at home.  Granted, it's for more than just Inventor (video, games, blah blah).  This is really cool though.  This cost 1/3 of what we just paid for at work.  I doubt I would've went this route like you said, but it still brings you down a peg or 2.....
Message 437 of 2,219
machiel.veldkamp
Well Neil.
Here is the thing. I'm a draftsman at a small company and we neeeeeed new PC's really. We are working with factory size models weighing in at 40K parts and we are running it on mid 2011 hardware.
Money is always an issue so I want to make a solid reccomendation for upstairs. Basically a PC that can hold a solid 9-10 every day ou of the week stable.
The idea is to build one system first and then look to see if we can upgrade the rest. (10 in total)
Is that possible with a non-overclocked system?
Message 438 of 2,219
mmaes
in reply to: machiel.veldkamp
@machiel.veldkamp My PC got an 11.90 with a 6 year old GPU...I am upgrading the GPU next week to a GTX960 and assume since it is a better card I will still be in the 11.5-12.0 range or higher.  All components for this build cost $1440.  Some things on my build could be considered overkill as I am running 32Gb G.Skill TridentZ 3200Mhz RAM and watercooled but it works and is much cheaper and faster than the Dell Precision mobile workstations we have now.
In short, for less than $1500 you can have a very fast machine that can deal with very large assemblies with no problem.
We are building a second one of these next week and found all the below parts on Newegg for $1437.91
Corsair Carbide Series 400R Graphite grey and black ATX Mid Tower Gaming Case
ASUS ROG MAXIMUS VIII RANGER LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboa...
EVGA GeForce GTX 960 04G-P4-3969-KR 4GB FTW GAMING w/ACX 2.0+, Whisper Silent Cooling w/ Free Instal...
CORSAIR RM1000i 1000W ATX12V / EPS12V 80 PLUS GOLD Certified Full Modular Power Supply Nvidia Sli re...
Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz LGA 1151 91W BX80662I76700K Desktop Processor Intel...
SAMSUNG 850 EVO 2.5" 500GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E500B/AM
Corsair Hydro Seriesโ„ข H100i V2 Extreme Performance Water / Liquid CPU Cooler. 240mm
G.SKILL TridentZ Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Mode...
(2) XIGMATEK XOF-F1254 120mm FCB (Fluid Circulative Bearing) Cooling System 120mm Volcano Red Case F...
Message 439 of 2,219
Neil_Cross
in reply to: mmaes
That's a quality build, it's entirely personal preference but coming from a 100% NVIDIA fan boy here and having never owned an AMD card in my life, I went with the R9 380 over the GTX 960 in my budget build and it came up trumps.  They're both at the same price point but the R9 380 had more to offer on paper.  But on paper it's all gaming focused stats, who knows how that translates here.
Message 440 of 2,219
Interesting, really not sure what to make of my results, love to hear some peoples thoughts!
