How does Splitter tool work in FORMS?
troyostrander
troyostrander
I can't figure this one out. I would assume it would make columns?
kacper.suchomski
Hi
The splitter is not particularly visible in this theme.
The help file contains a detailed explanation of the forms window and the commands contained within it:
https://help.autodesk.com/view/INVNTOR/2027/ENU/?guid=GUID-40B1D589-4D0C-4B46-AB52-896F0C7D78F4
Kacper Suchomski
Ihor_Radikhovskyi
Hi @troyostrander
To answer your question directly: no, the Splitter tool doesn't make columns.
A Splitter is just a draggable boundary. If you place it between groups, the user can drag that line to resize areas in the active form.
To actually make columns (place parameters side-by-side), you need to use the Row element. Just drag a Row into your form, and then drop your parameters inside it.
harvey3ELEA
Like Ihor stated above, you can arrange the form editor like this (notice row one components are tabbed differently in the editor vs. row 2 items):
To get this:
pkomatlapalli
Hi @troyostrander,
Just checking in to see if you’ve had a chance to review the suggestions shared from Kacper.suchomski, Ihor_Radikhovskyi and Harvey3ELEA  help resolve the issue? If so, please consider marking the "Accepted Solution" button.This helps other community members find answers more quickly.
If the issue is still occurring, feel free to share any updates, additional details so the community can continue assisting you.
Looking forward to your update!
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
