How does one accept the self-intersection in a sweep operation?
joh13399
Message 1 of 15
joh13399
I'm trying to sweep this circle along the spline you can see in the image, but when sweeping along the line, inventor gives the error that the result would self-intersect.
There is no option to accept this, so I'm here on the forums asking how I tell inventor that a self-intersection is fine.
To specify further, I'm expecting this to work like a normal sweep, where the circle is translated with the normal plane being parallel to the tangent of the line. I want to tell inventor to handle the result as a boolean OR operation, meaning that if there is an intersection from two points along the line, the intersection should be solid if it's solid at point X OR point Y.
How do I do this operation?
Replies (14)
Message 2 of 15
JDMather
Did you Attach the correct file?
The file that you Attached here does not look like your image?
If you attempt to Offset the path - what do you observe?
Message 3 of 15
joh13399
I thought I attached the correct one, but I've re-attached it to be sure.
I can't select the path with the thicken/offset tool.
Message 4 of 15
JDMather
Edit sketch.
Attempt to Offset the sketch path.
What do you observe?
Message 5 of 15
joh13399
This is what I see:
Message 6 of 15
j.palmeL29YX
Jürgen Palme
Message 7 of 15
joh13399
I don't see the issue. The solid should still be able to be created...
The result should be the same as splitting the sweep into two, three, etc. sweeps excluding only the intersecting portions.
Message 8 of 15
j.palmeL29YX
I don't understand what you want to say, but:
The radius of the circle must not be greater than the radius of the path curve.
To check this try a sweep with a diameter 19 or 18.5 (I dont know the path radius at the marked points).
If this works you should consider another path or a smaller circle (I don't know your intention).
Jürgen Palme
Message 9 of 15
joh13399
I'm saying that the sweep should create a crease where the intersection is, and that the intersection itself is acceptable to me in the geometry.
I'm also saying that there is no apparent problem with the path, even if there is an intersection, the resulting geometry should still be able to be solved and created.
Message 10 of 15
j.palmeL29YX
@joh13399 wrote:
... the sweep should create a crease ...
... the resulting geometry should still be able to be solved
That's YOUR opinion. Inventor has an other one, sorry.
Jürgen Palme
Message 11 of 15
joh13399
That's YOUR opinion. Inventor has a other, sorry.
No, no. That is no opinion. It is a fact that the geometry is solvable, and it is another fact that the geometry will have a crease. How do I do this?
Message 12 of 15
JDMather
@joh13399
What are you modeling?
How will it be manufactured?
What is the material that will crease?
Do you have a photograph of similar real world part with the crease?
Message 13 of 15
joh13399
This is a support peg that will be 3D printed with PLA plastic. The crease will not be bent via press, roller or brake, but be baked into the print itself.
Message 14 of 15
swalton
As I understand it, Autodesk programed Inventor's sweep function to error on self-intersections.  While it is possible to define results from self-intersections, Autodesk didn't.
You won't be able to get a creased shape with a single Inventor sweep function.  You might be able to get the shape you want by combining several features, or with some sort of multi-body workflow.
Why do you need the crease?  How do you intend to get that shape on a real-world part? Maybe there is another workflow that can get you the shape you want.
I've never had to to model such a shape, so I'd have to make several attempts before I could give you a recommended workflow.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 15 of 15
johnsonshiue
Hi! Indeed, Sweep in general does not like self-intersection, particularly at the same path segment or the profile itself. There are workarounds. Here is one solution. Basically, you make the circle smaller like 10mm diameter. The sweep will work without a problem. Then use Thicken feature (9.5mm) to enlarge the tube. Please take a look at attached part.
Many thanks!
Software Test Engineer
