How do you move freeforms without changing them?
New to Autodesk
I_Forge_KC
Try:
Move Bodies (under the modify group)
or
Direct [Edit] (under the modify group also) - Notice on this one I set the selection filter to SOLIDS instead of FACES.
K. Cornett
Generative Design Consultant / Trainer
mcgyvr
Move bodies tool located in the "Modify" pane (in the dropdown arrow area potentially) on the 3d model tab of the ribbon..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
As a new user of Inventor are you sure you should be using "freeform"?
johnsonshiue
Hi! Besides Move Bodies, you can also use Direct Edit command -> Solid selection.
Many thanks!
Software Test Engineer
