Inventor Forum
How do I upload custom property format of parameter in FX to other files
2 REPLIES 2
ErikvRy
181 Views, 2 Replies
ErikvRy
Hi all,
Thanks for reading.
I have changed the property format setting of the Nominal value in FX to a custom proppertu format. See prtscrn below. If you right click in the fx parameterfield you want to change, you get a pop up with the option to change to custom property format. And then the window you see on the left in that prtscrn.
To be more precise: I removed the trailing zero's as more precision than mm² is not a necessity, and with trailing zero's it does not fit into our title block.
Now I want to change that parameter format, in all other file's as well. How do I do that?
Please make the sollution look difficult, or I feel stupid.... (Not really) Thanks.
Erik.
Hi all,
Thanks for reading.
Erik.
Labels (2)
2 REPLIES 2
pcrawley
in reply to: ErikvRy
pcrawley
You're not stupid - it's a good question.  As far as I know, there isn't a button for that - unless the formatting is available from the API, in which case a couple of lines of iLogic would do the trick.  (I will have to look!)
(Edit: I looked. It is.)
You could set the formatting in your part template - then all future parts will behave correctly.
Fixing parts from the past may be as difficult as you are hoping.
Peter
Peter
pcrawley
pcrawley
Try this.  Reading the code should show how you can tweak it, but I made it look specifically for your parameter called "Oppervlakte".  Feel free to edit 🙂
For Each oParameter In oPartDoc.ComponentDefinition.Parameters.UserParameters
	If oParameter.ExposedAsProperty Then
		If oParameter.Name = "Oppervlakte" And oParameter.Units = "mm" Then
			 oFormat = oParameter.CustomPropertyFormat
			 oParameter.ExposedAsProperty = True
			 oFormat.PropertyType = Inventor.CustomPropertyTypeEnum.kTextPropertyType
			 oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
			 oFormat.Units = "mm"
			 oFormat.ShowUnitsString = False
			 oFormat.ShowLeadingZeros = True
			 oFormat.ShowTrailingZeros = False
		 End If
	 End If
Next oParameter
Peter
		 End If
	 End If
Next oParameter
Peter
