- Mute
- Permalink
- Report
I put together an assembly a while back and I have since then added and removed certain parts.
Example: I have a certain part called A. If I insert the A part 10 seperate times then in the assembly I have parts
A:1, A:2, A:3, A:4, A:5, A:6, A:7, A:8, A:9, A:10.
If I delete A:4 and A:6 for some reason then place two more A part into my assembly then I now have parts
A:1, A:2, A:3, A:5 A:7, A:8, A:9, A:10, A:11, A:12.
I know that I can manually change the numbers to get them in order. But if I add another part then it will be called A:13. Since I deleted A:4 and A:6 I no longer have parts by those names in my assembly. I want to be able to somehow reset the numbers automattically and put them all in order. I hope this all makes sense.
Thanks in advance.
- SethL
