How do I prevent adaptivity from turning on?
Cris-Ideas
Advisor Advisor
Cris-Ideas
How can I prevent parts from getting adaptive?
I mean turn it off totally.
Now when I want to project something on to a sketch in the part from assembly level, this part gets adaptive by default.
But I do not want that. This is just to slow.
So I than have to turn adaptivity off manually, many levels, what is rather tedious and time consuming.
So I am wondering, is there a way to just not allow parts to become adaptive.
Cris.
Cris,
https://simply.engineering
ampster40
Did the option "Features are initially adaptive" get enabled somehow?  (App options > Assembly tab)
HTH
Cris-Ideas
No, it is off.
I think this option make everything adaptive by default on creation.
Cris.
Cris,
ampster40
Not sure if there is an option to disable that since more than likely that is a requirement if modifying a part at the assy level and you need to depend on something outside the part .ipt file.
Not much help there, Good Luck!
Frederick_Law
Try different setting in "Cross part geometry projection"
