How do I measure the loop length of a 3D Sketch and set it as a parameter?
JohnRambo4
JohnRambo4
How do I measure the loop length of a 3D Sketch with splines and set it as a parameter? For example I want the total length of a hose to be saved as a parameter to show up the Description or QTY field on a drawing. Obviously you can measure it with the Measure tool, but how to set the length to a Parameter? Thanks.
kacper.suchomski
Hi
This is a question for @bradeneuropeArthur
Kacper Suchomski
andrewiv
You will have to have an iLogic rule to accomplish this.  Here is a rule that used to use for this exact purpose.  I would set this rule to run on the geometry change trigger.
Dim oDoc as PartDocument
Dim se As SketchEntity3D
Dim oParameters As Inventor.Parameters
Try
	oDoc = ThisDoc.Document
	se = oDoc.ComponentDefinition.Sketches3D("3D Sketch1").SketchLines3D(1)
	oParameters = oDoc.ComponentDefinition.Parameters
	oParameters.Item("HOSE_LENGTH").Value = ThisApplication.MeasureTools.GetLoopLength(se)
Catch Ex2 As Exception
	MessageBox.Show ("ERROR, HOSE LENGTH VALUE WILL NOT UPDATE" & vbCr & vbCr & vbCr & Ex2.Message, _
		"SKETCH LOOP LENGTH ERROR", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Andrew In’t Veld
Designer / CAD Administrator
johnsonshiue
Hi! Another approach is to use an iLogic rule to get the volume of the tube and divide it by the tube cross section area. The result should be the length.
Many thanks!
Software Test Engineer
JohnRambo4
This worked. I just needed to create a HOSE_LENGTH parameter before running the code, and checking the Export box in Parameters. Now I can have the length populate in the part description. Thanks. How do I get it to auto update on geometry change?
Strange there isn't a way to dimension the whole length in a sketch but whatever.
