just alil mist comin out a part
Solved by CCarreiras. Go to Solution.
Hi!
Don't replicate posts 🙂
Inventor is a mechanical 3D design modeler, like they say " digital prototyping software". The software can do some animations, but only with the parts, like a door opening, or something like that, mobile elements from machines. Spray.... we can t model spray, so we can't do it moving.
You can model the device in Inventor and insert it in 3D Studio max, or Maya, and work there to achieve professional visual effects.... It's not easy to work with them, but the results are amazing.
(This is the software where was made SHREK and other animation movies)
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Hi!
Hi!
I don´t know what you donne in Max.. but
If it is a solid, yes. If you can export that to step, iges, or any cad format, you can open in inventor
If it is only animation, no.
Hi!
ok can i take a animation from inventor and import in 3D Studio max
No... just the model... you can only share the solids between the programs .
Animation are not compatible between them.
ok can w.e Animation i make in 3D Studio max a avi file an is there a fade control in 3D Studio max like inventor
