How do I get Inventor to calculate and sum up painted faces in an assembly.
Hi everyone. I have a problem in Inventor. I have an assembly containing several parts, sheet metals and sub-assemblies. All in the same material - but some of the faces are coloured red for show the inside of my assembly (for the painter to see whats inside and whats outside). I need to determine the total areas of lets say all in red (RAL 2004) and all in normal steel gray. How do I get a total list with the total red square meters and total gray square meters.? I hope some of you can help. BTW Im really new to computing in Inventor Ilogic so I hope you will be pretty precise :slightly_smiling_face: Thanks.
Accepted solutions (3)
Replies (14)
CCarreiras
Hummmm, i don't know if it is possible, i guess not.
CCarreiras
Hi. I find that i bit odd. The way I see it Inventor must have an unique ID for each face and thereby the properties for that face. It would then help me if Inventor cound give me a total list of all areas (1 to 400) for example and then state the dimensions (x,y,z), maybe the area (which it haves anyway) and then the RAL code of that particulary area. If so - then we could get Inventor to export this to Excel and inthere its possible to sum up the cells which contains identical information such as the RAL code. Hope you get my point. :slightly_smiling_face:
pball
Anything* is possible!
This should get every surface in a part. I also learned about using a dictionary in VBA, never used one before and I really like it for dynamic things like this. Probably could clean things up if I actually learned how to use them properly but proof of concept works.
Public Sub paint()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oFaces As Faces
    Set oFaces = oPartDoc.ComponentDefinition.SurfaceBodies(1).Faces
    Dim Colors As Object
    Set Colors = CreateObject("Scripting.Dictionary")
    Dim oFace As Face
    For Each oFace In oFaces
         Colors(oFace.Appearance.DisplayName) = Colors(oFace.Appearance.DisplayName) + oFace.Evaluator.Area
    Next
    For Each Item In Colors
        Debug.Print "Paint: " & Item & " Area: "; Colors(Item) & " cm^2"
    Next
End Sub
*Not really but I have scripted two things users have said were impossible so far
edit:
If you can't figure out converting this to iLogic and getting it to work in an assembly I can help out more later, but for now I hope this helps.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
mcgyvr
Here is @pball code converted to ilogic..
    Dim oFaces As Faces
    Dim oFace As Face
    Next
	MessageBox.Show("Color: " & Item & vbLf & "Area: " &Colors(Item) & "cm^2", "Surface Area by Color")
    Next
pball
Here is the final assembly level iLogic code. You'll just have to figure out what you want to do with the final results.
The code is pretty straight forward and is based on using the BOM. The BOM is the only way I know of to get access to every part and its quantity. I'm quite proud of this code, it's something I probably would of never done if you hadn't of asked.
Sub Main
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the BOM
    Dim oBOM As BOM
    oBOM = oDoc.ComponentDefinition.BOM
    oBOM.StructuredViewFirstLevelOnly = False
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    oBOMView = oBOM.BOMViews.item("Structured")
    Call PaintRecurse(oBOMView.BOMRows, Colors)
    For Each item In Colors
        msg = "Paint: " & item & " Area: " & Colors(item) & " cm^2" & Iif(msg <> "",vbCrLf & msg,"")
    Next
    MsgBox(msg)
End Sub
Private Sub PaintRecurse(oBOMRows As BOMRowsEnumerator, Colors As Object, Optional SubQty As Integer = 1)
    On Error Resume Next
    ' Iterate through the contents of the BOM Rows.
    Dim i As Long
    For i = 1 To oBOMRows.count
        ' Get the current row.
        Dim oRow As BOMRow
        oRow = oBOMRows.item(i)
        'Set a reference to the primary ComponentDefinition of the row
        Dim oCompDef As ComponentDefinition
        oCompDef = oRow.ComponentDefinitions.item(1)
        If (oCompDef.Document.DocumentType = kPartDocumentObject) Then
            Dim oFaces As Faces
            oFaces = oCompDef.SurfaceBodies(1).Faces
            Dim oFace As Face
                Colors(oFace.Appearance.DisplayName) = Colors(oFace.Appearance.DisplayName) + oFace.Evaluator.Area * oRow.ItemQuantity * SubQty
            Next
        End If
        'Recursively iterate child rows if present.
        If Not oRow.ChildRows Is Nothing Then Call PaintRecurse(oRow.ChildRows, Colors, oRow.ItemQuantity * SubQty)
    Next
End Sub
Thank you so much guys. You really saved my day. Just a small thing - how do I change the units from cm^2 to m^2?
pball
You can just multiple the cm^2 to get m^2 like so.
msg = "Paint: " & item & " Area: " & Colors(item) * .0001 & " m^2" & Iif(msg <> "",vbCrLf & msg,"")
Arh so - that makes totally sence when you see it. Final thing. How can I get the code to export it to an excel sheet? So that material in one colum and the area in another? Once again thank you very much or your support.
pball
Alright this exports the info to an excel file in the same folder with the same name as the assembly you run it in.
I'm kinda jealous of iLogic since it has simple excel functions for reading and writing unlike VBA. Though there isn't a way to create a new excel with those nifty functions that I saw.
I also added a few additional remarks to help people know what's going on.
Sub Main
    Dim oBOM As BOM
'Create a dictionary to store paint color and area in Dim Colors As Object Colors = CreateObject("Scripting.Dictionary")
'Call subroutine to calculate paint areas Call PaintRecurse(oBOMView.BOMRows, Colors)
'Set output file name xls = Replace(ThisDoc.Document.fullfilename,".iam",".xlsx")
'Check if output file exists, if not create it If (Dir(xls) = "") Then excelApp = CreateObject("Excel.Application") excelWorkbook = excelApp.Workbooks.Add excelWorkbook.SaveAs(xls) excelWorkbook.Close End If
'Open output file for writing GoExcel.Open(xls, "Sheet1")
'Add header info GoExcel.CellValue(xls, "Sheet1", "A1") = "Color" GoExcel.CellValue(xls, "Sheet1", "B1") = "Area" num = 2
'Loop through each color and add to the excel file For Each item In Colors GoExcel.CellValue(xls, "Sheet1", "A" & num) = item
'Area is returned in cm^3 by default so multiply by factor to get m^3 GoExcel.CellValue(xls, "Sheet1", "B" & num) = Colors(item) * .0001 GoExcel.CellValue(xls, "Sheet1", "C" & num) = "m^3" num = num + 1 Next
'Save and Close excel file GoExcel.Save GoExcel.Close MsgBox("Paint colors exported to " & xls) End Sub Private Sub PaintRecurse(oBOMRows As BOMRowsEnumerator, Colors As Object, Optional SubQty As Integer = 1) On Error Resume Next ' Iterate through the contents of the BOM Rows. Dim i As Long For i = 1 To oBOMRows.count ' Get the current row. Dim oRow As BOMRow oRow = oBOMRows.item(i) 'Set a reference to the primary ComponentDefinition of the row Dim oCompDef As ComponentDefinition oCompDef = oRow.ComponentDefinitions.item(1)
'Checks if current item is a part, skip if not a part If (oCompDef.Document.DocumentType = kPartDocumentObject) Then
'Set a reference to the faces on the current part Dim oFaces As Faces oFaces = oCompDef.SurfaceBodies(1).Faces
'Loop through all faces of part and add the appearance and area to the dictionary Dim oFace As Face For Each oFace In oFaces Colors(oFace.Appearance.DisplayName) = Colors(oFace.Appearance.DisplayName) + oFace.Evaluator.Area * oRow.ItemQuantity * SubQty Next End If 'Recursively iterate child rows if present. If Not oRow.ChildRows Is Nothing Then Call PaintRecurse(oRow.ChildRows, Colors, oRow.ItemQuantity * SubQty) Next End Sub
karthur1
I was looking at this code example and I have a question.  I first ran the code with all colors the "Default" color.  It worked just fine.  I then changed one of the surfaces to "Black" and ran it again.  Now it lists the area of the "Default" surfaces as well as the area of the "Black" surfaces.
Now I removed the black surface and changed it back to the "Default" color and re-ran the code.  When I do that, the "Black" area is still listed in the excel sheet.  Is there a way to clear all the values each time it is ran?
Kirk
pball
Are you deleting the excel file between running the code? The code is only updating the excel file, so if you reduce the amount of colors previous lines would be left in the file. It should be easy enough to either delete or clear the excel file if it already exists.
karthur1
No, not deleting the excel between running the code.  It does say that the .xls file already exists....overwrite?( Y/N).
I just thought that when it recreated the .xls file, that it would be a new file without the old colors left behind.
I have a slightly different approach to this problem. I've written an iLogic utility that will calculate the painted area of an assembly. The general problem is that surface area of an assembly includes all faces - see example here: https://clintbrownblog.files.wordpress.com/2019/09/40clintbrown3d-autodesk-inventor-assembly-surface...
My iLogic utility creates a shrinkwrap of the assembly, does the surface area calc and then deletes the shrinkwrap. Surface area calcs are saved to iProperties in both mm3 and cm3
https://clintbrown.co.uk/2019/09/28/assembly-surface-areas-for-paint-or-coatings/
johnsonshiue
Hi Guys,
Or, you can check out similar tools at Inventor App store.
https://apps.autodesk.com/INVNTOR/en/List/Search?isAppSearch=True&searchboxstore=INVNTOR&facet=&coll...
Many thanks!
Software Test Engineer
