How do I get inventor to use the full monitor screen? The windows bar is taking up some valuable space at the bottom of my monitor. Maximize doesn't fill the entire screen, that windows bar takes up a good 1 or 2 cm of space!
Solved by Christopher2222. Go to Solution.
Ah, it appears more to do with windows than inventor.
right click on the taskbar select properties, then uncheck lock the taskbar and check Auto-hide the taskbar.
Hi! Another option is to use "Clean Screen" option in View -> Windows after you open a file in Inventor.
Many thanks!
