How do I flip the orientation of a frame member once it's created?
JBEDsol
JBEDsol
I've got an issue where I have tons of frames to add but they seem to come in at random.  When I create one I have the option to flip it (useful for angles).  However once it's created I don't have that option anymore.  Is there a way to do this?
Cadmanto
If you select the frame member and select edit using FG, don't you see the orientation selector on the right side of the window?  That allows you to select the orientation of how you want the part to seat and be rotated.
https://forums.autodesk.com/t5/inventor-forum/frame-generator-orientation-problem/m-p/8549408#M72989...
https://blogs.rand.com/manufacturing/2019/02/inventor-2019-frame-generator-enhancements.html
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JBEDsol
This is what I'm talking about.
Cadmanto
This is the mirror function in FG.  Apparently it was suggested as an idea and archived.  Why, I have no idea.  You can still cast a vote and comment on it to try and res-erect it.
https://forums.autodesk.com/t5/inventor-ideas/mirror-frame-member-when-editing-existing-frame-member...
Inventor Pro 2020
Best Regards,
Scott McFadden
johnsonshiue
Hi! Once the member is created, you can only align the member. You cannot flip it. It is because flipping can lead to modeling errors and end treatment errors. To flip, you will need to delete the member and recreate it.
Many thanks!
Software Test Engineer
