@Derek00111
Your Sketch2 is not fully defined - it should be placed at the Origin Center Point.
Was this not covered in the tutorial instructions?
Work Plane 1 and Axis are not needed if original sketch had been placed at the Origin.
Sketch6 location is not defined in space - it should be centered at Origin.
Sketch9 is missing diameter dimension of the circle.
Did the instructions not cover these steps?
I do not see a sketch with Projected Cut Edges in the file that you Attached?
On Step 4 I had trouble picking the left line for .06 dimension looking straight at the model.
If I rotated it a bit it was easier to pick the line (or endpoint).
See Attached file for how I place my sketches at the Origin....
Also, when selecting the line to place the small circle be careful to NOT select the midpoint of the line as the midpoint is very close the the intended location of the circle.
Always, always, always (at least as a beginner) model with symmetry about the Origin Center Point.
This is the foundation of the BORN Technique of modeling.
