Part "neoprene" consists of 2 revolved bodies "front" and "back". I would like to individually control visibility for each revolved body.
Suppress kinda does what I want, but not really. Obviously I can make separate parts, but that doesn't meet my design goals.
Thanks so much
Joe
Solved by cidhelp. Go to Solution.
Hello @theycallmevirgo ,
there is only 1 body in this part.
You have to activate the "New Body"-option for the back-revolution. Then you have 2 bodies and can control visibility.
Hi
In the second operation panel, you should select the new solid variant (not add material). At the moment, you have one solid (in separate spaces).
You will then be able to control the visibility from your browser.
Kacper Suchomski
