how cut part from sphere
Message 1 of 9
Hi
I am new in autodesk inventor
have two question
how cut part from sphere, for exemple I have hollow sphere and want cut it in the middle of the radius or further from center, then remove this cut and get something like spherical aquarium?
and how make spherical cut, hemisphere low relief ?
Replies (8)
Message 2 of 9
mdavis22569
Welcome to the forum ..
There are quite a few different ways:
Subtract/Cut
Derive
Scuplt
Multi-body part
have you gone thru any of the tutorials?  There should be some good examples there ...or you can google it and find a lot of Youtube, Screencast videos
https://www.google.com/search?q=hemisphere+low+relief&oq=hemisphere+low+relief&aqs=chrome..69i57&sou...
This link has results showing most of the ones above that I listed.
Mike Davis
Message 3 of 9
Thank you! helpful
Message 4 of 9
if i have sphere in part mode, what is the best way to cut it? because as a separate part I use split tool but if part already have something and i want add this sphere, plane no passes through and can't select the cut line.. I can combine it in assembly, but seems it's not the best idea create separate part only for sphere=)
what i m doing wrong?
Message 5 of 9
mdavis22569
share what you have .... but why do you need to cut it ?
Maybe redraw it so you're on the origins. It's (in my opinion) to model from this area, it;'s giving you free planes, axis's  and origin point.
You can make it from a revolve ..
You can do it with a multi body with each being a half.
Mike Davis
Message 6 of 9
just hollow hemisphere created with revolve  and plane where i want cut it and remove one part. so I cut it with the sketch from the side, but not sure if this way is the best
Message 7 of 9
mdavis22569
If you want to remove from the half to the work plane
You can cut it from the top down, or you can make a rectangle/sq on the work plane and extrude cut it from the work plane out ...
Can use the split tool and make it 2 pieces...
Again, I would go to tutorials or YouTube videos and see how some the examples work.
Mike Davis
Message 8 of 9
Looking for boolean operation like cut of two shapes, because boolean subtract is not the way I think
https://www.youtube.com/watch?v=6JpK2bEJP-I
for example if I want cut difficult structure from one cube inside another to get something like cast and mold, or same, just cut intersected zone from one of two intersecting spheres?
Message 9 of 9
mdavis22569
you could derive subtract or sculpt
the subtract is what they did in the video
here is sculpt
https://www.youtube.com/watch?v=oQVkzfgrYM8
for what you're explaining ...I'd probably use sculpt ...but that's me
Mike Davis
