I've been trying to sharpen the edges of the fan blades I'm designing but chamfer didn't work since I keep receiving an error message and even though I shorten the distance.
Could you please help me with this so I can also improve my skills.
Thanks in advance and have a great day.
Solved by johnsonshiue. Go to Solution.
Solved by JDMather. Go to Solution.
Solved by Cadmanto. Go to Solution.
I was able to get .75 cm on both sides.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
I didn't spend a lot of time on this and I think I "sharpened" the wrong edge, but you might get some ideas from the Attached file.
Hi! Here is a solution I found by using Offset Surface and Move Bodies. I am able to get very sharp edges. Please take a look at attached part.
Many thanks!
