Inventor Forum
How can I remove reference parameters?
2 REPLIES 2
1480 Views, 2 Replies
I Imported an AutoCAD dwg and used the project dwg geomery tool to make a sketch from it, but it turns out that all the dimensions are totally wrong. How can I delete/unlink reference dimensions and input them manually?
2 REPLIES 2
jhackney1972
The AutoCAD drawing has been referenced into the sketch which makes it "Reference" geometry.  In my color scheme, reference geometry is dark green.  Edit the sketch, select all the geometry, and then right click and select "Break Link".  This changes the geometry to normal sketch entities.  Then select the driven dimensions and change them to driver dimensions and add any other dimensions you desire and you are good to go.  The background image is the AutoCAD drawing which you can turn off.
Please see Screencast
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
kelly.young
Hello @Anonymous This can be frustrating but is a simple fix.
  • Edit the Sketch
  • Select All Lines
  • RMB Delete Constraints
  • Add new constraints
  • Finish Sketch
  • RMB on dwg link in browser tree > Delete
Please select the Accept as Solution button if a post solves your issue or answers your question.
