How can I make a Voronoi pattern on my dome?
Message 1 of 8
Hello Everyone.
I've this dome I want to build up based on a voronoi pattern. Every edge has to be intact so there needs to be an edge of 15mm around each hole before the voronoi pattern starts.
I've tried using https://www.voronator.com/ but it ofcouse makes the hole dome into one voronoi pattern. How can I do this correct as I wish?
Do I need to wrap a image around the dome and 3D sketch all structures for extruding a voronoi pattern or how is this achievable.
Thanks. Best regards.
Replies (7)
Message 2 of 8
WHolzwarth
You can use the Voronator base geometry, and complete it with Inventor features.
Show us, what you have as Inventor files.
Walter Holzwarth
Message 3 of 8
I don't think it will be good?
I have attached the sphere also and OBJ file if you want to make / improve in Voronator quick and then the Sphere model I made from Voronator myself.
As shown in this picture I'm just playing around with a concept model for a underwater robot. Dome3.png
Message 4 of 8
Sergio.D.Suárez
Hi, Another way to get a good Voronoi is through Rhino, the grasshopper module contains some interesting plugins. It is very good because you can customize it to your liking. Then if a solid is formed, it can be exported as a step to open it as an inventor. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 5 of 8
Unfortunately I can't try Rhino since I did it two years ago so won't be able to run the trial again.
Message 6 of 8
WHolzwarth
It can be done in Inventor, after reducing the mesh numbers to only 10% of the initial numbers.
Unfortunately the resulting IPT is near to 70 MB. Therefore only a picture.
Walter Holzwarth
Message 7 of 8
Thanks for giving that a shot and showing it's possible.
Do you mind breaking down in text how you went about it and achieved it?
Thanks again for taking the time.
Message 8 of 8
WHolzwarth
Only a few words:
- Reduce the mesh elements of the initial file, perhaps with Meshmixer
- Open it in Inventor
- Convert the initial mesh there to a solid, using the MeshEnabler App
- Create a partial sphere surface at one of the cutouts
- Thicken that surface to a new solid
- Drill solid
- Polar pattern from that
- Join Combine it with the Voronoi base
Last step is mirroring to another body. I didn't combine further, because of waiting time.
Walter Holzwarth
