How can I create rib with draft that is extended to a profile?
SEC_CAD
SEC_CAD
I need to create a rib that terminates at a profile that has a draft angle. All the online videos I have found use trivial square geometry or bound the rib at both ends (e.g. inside a shelled container).
I am trying to create a feature like Extrusion2, in the attached part file, but terminated at the profile.
I have tried ribs running normal and parallel to the sketch plane.
Rib1 allows me to specify a draft angle but does not let me extend to the profile.
Rib2 does not allow me to specify a draft angle but does let me extend to the profile.
How would I go about creating such a rib with a  draft that terminates at the profile?
THANKS
admaiora
just don't use the Rib command
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
JDMather
I changed your design a bit - see Attached...
SEC_CAD
Thanks @JDMather and @admaiora . Both of these methods will work. Thank you both for taking the time to prepare the video and part file.
