How can I create a table in my .ipt file?
I'm creating a 3D calendar, but I'm having a hard time inserting the days of the week. Is it possible to add a table in my .ipt file that will act as a monthly calendar?
For example, row 1 will contain "S M T W T F S", and the following rows will have the numbered days.
I've tried exporting an Adobe Illustrator file as a .dwg, then copying and pasting it into the .ipt file in sketch mode. It pastes fine, but it won't cooperate. Whenever I try and rotate it, it'll only rotate certain parts of the drawing.
Does anyone have a better solution to this?
Here's a screenshot of what I'm talking about. Notice how only the "4" is being rotated, even though I selected everything?
Curtis_Waguespack
Hi jereed,
Welcome to the forum.
Try creating a Sketch Block from your pasted in geometry, then you can rotate it as a single object:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-1F49F883-CDDA-4E2E-9952-98DB658B608B
I hope this helps.
Curtis
Yes, that worked! Thank you so much! 😄
