Inventor Forum
how calculate area for surface
26 REPLIES 26
Message 1 of 27
25119 Views, 26 Replies
I have a cast aluminum part I need to calculate the surface area for our plating process.  I have done a simple area, its not right (.015ft^2).  I have derived it as a surface but can't get a volume calculation.  Any ideas?
26 REPLIES 26
Message 2 of 27
Message 3 of 27
mrattray
The results in this menu are not correct?
Post the part here.
Mike (not Matt) Rattray
Message 4 of 27
in reply to: mrattray
I can't post the part, it is too big. 9MB
Message 5 of 27
JDMather
You have imported a part.
First thing I would do is sketch a known length (and units) line and verify that your import is the correct size.
Have you done that?
If you roll up the EOP and zip the file - is it still too large to attach here?
If so, send it to jmather_at_pct_dot_edu
Message 6 of 27
in reply to: JDMather
I hope the scale is OK, cause we just got done using this model to build an entire assembly line.
Message 7 of 27
swalton
I looked at your second screenshot, the iprops one.
A cube of aluminum that weighs 0.008 lbs is 0.438 inches on a side.  See my screenshot.
Is that close to  the size of your part?
Steve Walton
Inventor 2023
Vault Professional 2023
Message 8 of 27
in reply to: swalton
The part is @ 13in X 4in X 3in total.  The surface area of just one face on the where the halves bolt together is 3.902 IN^2
Message 9 of 27
mrattray
What do you get when you go to the solid part, not the surface import and pull up the iProperties page, physical tab as swalton and myself have shown?
Message 10 of 27
Message 11 of 27
mrattray
I think your import is boogered. Can you post the part file somewhere? Try zipping it and posting it to some third party host since it exceeds AutoDesk's limit. (I like drop box, personally)
Message 12 of 27
Message 13 of 27
mrattray
Does this look a bit more accurate?
Message 14 of 27
mrattray
All you need to do is click "Rebuild All".
Message 15 of 27
Mine didn't work, it changed but doesn't match yours.
Message 16 of 27
JDMather
The last number you show is what I get for the pins, not for the caliper body.
Message 17 of 27
Is is because there are 2 bodies and iProperties grabs the first?
Message 18 of 27
mrattray
Sorry I was playing around with a combine when I snipped that shot. Here's one where all I did is open your file, click rebuild all, open iProperties and click update:
Message 19 of 27
mrattray
You can select what bodies are considered in the first drop down. "The Part" is everything in the ipt file.
Message 20 of 27
rdyson
Right Click the Body in the Browser > Properties
PDSU 2016
