Hover over the part= text box appears
Is it possible to create a text box that appears if you hover your mouse on a part in an assembly. It could give information about a part condition which is saved in an excel sheet or something.?
Best,
Lukas
mcgyvr
A components iproperties are typically where data about a part is stored.. Description/revision/status and many more default fields plus you can define all the custom iprops you want to.
Not accessible via hover out of the box but you simply right click and select iproperties..
No need for excel
There is also Engineers notebook but its rather basic/limited..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
I'm sure that wish some advanced VBA/Visual studio stuff you could do what you want.. But its not out of the box functionality and would require advanced coding..
Xun.Zhang
Hello Lukas,
How about add some Engineering notebook as a workaround?
Hope it helps!
Xun
johnsonshiue
Hi! Another workflow you could try is using MBD (Annotate). You can create a leader text on the part or the assembly directly (2018.1 and later). Then you can create Design View Reps to control visibility of the annotations.
Many thanks!
Software Test Engineer
thanks, that sounds great, however im using inventor 2017
thanks for the info. Im aware of the iproperties, I was still hoping to "pimp" my project. Ill take a look at the engineering notebook.
