Home base button does not work
Message 1 of 16
I recently installed the 2020.3 update and i found that the home button is broken. When I open inventor application the programme freezes and all that appear is a grey window with all the icons on top and the home tab at the bottom.
I can open a part, assembly and IDW file individualy but when I close the tabs and press the home button the same problem occurs. The programme freezes. Inventor does not crash and closes.
Any ideas?
Replies (15)
Message 2 of 16
mdavis22569
Hi @Anonymous
Try the Inventor Reset Utility
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-t...
Mike Davis
Message 3 of 16
johnsonshiue
Hi! It is possible the My Home page was corrupted somehow. Our framework expert shared a trick with me. Here is what you do.
Close Inventor and go to File Explorer and the following folder.
“C:\Users\<username>\AppData\Roaming\Autodesk\Inventor 2020”
Delete "myhome.json"
Restart Inventor.
Does it work now?
Many thanks!
Software Test Engineer
Message 4 of 16
@mdavis22569 This did not solve the problem. The same thing occurs
Message 5 of 16
@johnsonshiue . I did this , but still when I press the home buuton Inventor freezes.
Message 6 of 16
mdavis22569
Do you have any addin's or iLogic?
Mike Davis
Message 7 of 16
johnsonshiue
Hi! It sounds like your machine is blocked from accessing a web page (My Home is a local web page). Make sure all critical Windows updates are installed and follow the instruction below to see if it works better.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
Many thanks!
Message 8 of 16
All the window updates are installed and I followed the instuction. I am now able to open Inventor application and is open successfully, but still when I then press the Home button Inventor freezes and the cursor is flashing.
Message 9 of 16
rafael.barata
I have exactly the same issue.
Any news about this topic?
Thanks.
Message 10 of 16
CGBenner
@rafael.barata @Anonymous
Hey guys,.. try this.  Right click on the Inventor shortcut icon -> Properties -> Compatibility -> Run as Admin... then try to open Inventor, does this help?
Chris Benner
Message 11 of 16
rafael.barata
@CGBenner
Thanks for your reply.
I tried that but it did not work. Do you have any other idea?
Message 12 of 16
CGBenner
Can I ask what browser you are both using?
Chris Benner
Message 13 of 16
Scott.Hawkins
When you say the icons at the top still appear do you mean the buttons on the ribbon?
If you close the Home tab so that the home tab is no longer visible at the bottom and then press the Home button, does anything change?
Scott Hawkins
Inventor Software Developer
Message 14 of 16
E.Leijer
Did you solve this problem? I got the same 😞
Message 15 of 16
rafael.barata
Yes. Uninstall every update until 2020.3 (including) and try. I think this was what I did. Then reinstall them again.
Message 16 of 16
E.Leijer
Thanks! I'll try that 🙂
