In Inventor 2018 when selecting an appearance from the drop down menu, the home and end keys on the keyboard no longer jump to the top and bottom of the list.
I use Aluminum a lot so it makes it much quicker to jump to the to of the list or for selecting 'clear override'
Is this a bug?
Solved by SharkDesign. Go to Solution.
Just realised that in 2018 Home and End are now bound to zoom commands.
Deleting these in the customise menu restores the use of home and end in the drop down.
James,
Home/End were also defined as the same Zoom commands in previous Inventor releases, so they should still work for you in those lists 2018. You shouldn't have to delete the shortcuts. I'll ensure it gets logged.
Chris
