hole wizard in 2020
lis_wang
hole wizard in 2020
lis_wang
I want to create a hole on a point in a direction which defined by work axis in 2020. How can I do that? There is 4 hole placement options in previous version. Now it seems only can use 2 options (a point on a sketch and concentric to a circular edge).
Thanks for reply.
Xun.Zhang
Hello @lis_wang,
This is called on point hole, just invoke Hole command and select the workpoint directly, then, you are all set.
Here is a video to show the workflow.
https://autode.sk/2ymnXcl
Hope it helps!
Xun
lis_wang
Thank you very much
