HOLE NOTE IN HOLE TABLES
This widget could not be displayed.
Good day All,
I would like to create a HOLE NOTE to use in my HOLE TABLES for sheet metal
parts which will reflect the DIAMETER of the hole only as the thickness is
in my title blocks.
Some where I am just missing the link to create a new Hole Note and then
assign it to the Hole Table.
Thanks in advance for any assistance
Wayne's PC
Inventor 2009
32Bit Edition - 2GB
XP PRO SP2
Intel Core 2 Quad CPU
Q6600 @2.40GHz
4GB RAM
NVIDIA Quadro FX1700 512MB
Wayne,
When you create a hole table the hole notes in the table are controlled by
the dimension style associated to each hole tag. By default the style
assigned to the hole tags will be the dimension style assigned to "Hole Tag"
in the active object defaults style. If you want to change that, create a
new dimension style with the hole notes formatted as you wish. Then edit
the object defaults style that is being used by your active standard style,
and set the object style next to "Hole Tag" to your newly defined dimension
style.
Alison Davis
Autodesk, Inc.
