I know about "Thread.xls"... but is there such a file that controls the dimensions that pop up in the hole command dialog box when you select a standard size bolt, for example a Flat head machine screw. The dialog box brings up the standard hole size and dimensions for the countersink. I would like to know if there is a way to change what comes up as the defualt dimensions there, rather than having to change them every time.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by Curtis_Waguespack. Go to Solution.
Hi cbenner,
In the same folder as the Thread.xls, there is a file called Clearance.xls, I think this is the file you're looking for, unless I've misunderstood.
I hope this helps.
Curtis
Thanks Curtis, exactly what I was looking for... except it had gotten moved to our design data folder on the network. That explains why I couldn't find it!
Chris Benner
