Hole depth ssymbol not showing
Paul-Mason
Paul-Mason
I manually added the hole depth info to a callout then, as it did not show, to check this I did the same on the parent view however the hole depth symbol dose not appear just a space where it should be. All the other symbols appear normally. I've NOT edited or deleted any fonts or characters. So I'm stuck as to why this has just suddenly started to happen.
As can be seen from the screen shot what is in the EDIT box is correctly formatted and the symbol show but not in the dimension on the actually IDW.
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
mdavis22569
Can you share the file(s)
Mike Davis
Paul-Mason
It fixed it self after I reboot of my laptop.
Inventor 2027 Pro
Xeon
