Announcements
How to get angular velocity of working point in Dynamic Simulation
Hi, is there a way to obtain the angular velocities of a working point in a dynamic simulation?
I can track the position and translational velocities but to fully analyse the motion i need to get to the angular velocities of my working point which is at the center of mass. Is there a way to do that?
Thanks!
Replies (10)
Still struggeling to find a solution for the angular velocity results! Anybody?
JDMather
Attach assembly here.
...and indicate what stationary reference point (or axis) that you want to measure your velocity relative to.
Hi, thanks for your reply. I attached my assembly. It's the cylinder with complex motion that i need to describe with its angular velocities and transitional velocities relative to the domain origin. Thanks!
Hey @JDMather
have you had time to look at my file? I'm sill wondering if i can get angular velocites of the working point..
Thanks alot!
JDMather
The assembly that you attached in this thread has a redundant constraint.
I thought you had a version were there were no redundant constraints and the simulation had an imposed motion set up and ready to go?
Ok, sorry i was not aware of that. I attached a newer version which should be ready to simulate! Thanks!
JDMather
Well, your mechanism is still overconstrained - but the Attached might get you closer.
Examine the Output Grapher.
Thank you very much for your reply! I will study this now..
lena.talkhina
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Hi @JDMather ,
i studied your assembly and it looks like you added a sphere and a bunch of constraints. Also there is another joint. Unfortunately i do not understand well enough how this works yet..
My aim is to transfer the movement the cylinders makes to a different simulation program which can describe the movement by applying rotational and translational velocities. I think the translational velocites i can get by simulating the Center of the Cylinder with Output grapher. For the rotational velocities i'm not sure how the get these still. I attached a drawing... Green lines are fixed with the cylinder. The black lines are stationary. Is this correct approach you think? How can i get this from Inventor...
From your Output Grapher i see a new rot. velocity in deg/s but i don't understand which rot. velocity it describes exactly..
Sorry to bother you with this still..
