Inventor Forum
Hole command clearance hole sizes
4 REPLIES 4
anthonyzepeda1969
596 Views, 4 Replies
Is there a reason why Inventor stopped at 3/8" screw sizes for clearqance holes? Hex Bolt clearance holes go up to 4" bolt size.
Is my hole feature outdated? Or did it change? I seem to recall it had larger sizes.
4 REPLIES 4
My table acts the same for this Hex machine screw selection. Inventor hole and thread information is just a guideline and will not contain all the industry standards out of the box, but you may edit the table to expand/complete it:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inve...
More details here:
@anthonyzepeda1969 @Gabriel_Watson
A quick search online shows the standard size for Hex head Machine Screws only going to 1/2".  Hex Head bolts are a different animal.
But in either case, the table can always be edited with any missing standard sizes.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
That's unfortunate. Why go up to 4" on one type and not all the other? I would think they would add for Hex Bolts and Hex Screws at least. They did this for Socket Cap Screws , which, using larger than 2 inches is not common.
But thank You for the links. I will update spreadsheet.
I literally just found up to 2" with random search. Machinists handbook lists up to 3".
Are they 2 different animals?  Wow who knew?
But thanks for the links with instructions for editing the tables.
