Hole & thread notes
Hole & thread notes
Hole & thread notes
Fouad-l
Hi.
Could you explain what is the problem here?
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
hi @Fouad-l
I want to set default hole notes
When i create the hole note only thread specification will be present.
each & every time in need to edit the hole note.
to define no of hole or thread.
 And required thread depth, Tap drill dia & depth.
Fouad-l
Hi.
Right click the hole annotation and select Edit annotation style. Then add all you need and save.
Maybe you have to do that inside a drawing template to keep this settings.
Dont forget to change project permission to Read/Write before you do that.
NO.JPG I have changed but isn't working. Can you send the screen recording creating.
Fouad-l
Hi.
From the style Editing window, first you have to select from Note Format list which kind of hole you want to modify. If you look at the hole note when placing the annotation you will find (in your case) Blind - Depth thread. So to be able to edit this note you have to select it from the list in editing window before making the change.
 My inventor is in Spanish.
