- Mute
- Permalink
- Report
Good afternoon everyone
I wanted to model some contrate teeth which have been hobbed/generated.
Outer radius of hobbing cutter is 6mm.
I modelled the cutter, and then implanted this 20 times in an assembly which contains the pinion to be hobbed. The aim is to break down the continuous process of hobbing into 20 steps for a half of a single tooth space. This could then be mirrored to create a single tooth, albeit with slightly jagged areas because of the 20 steps.
From within the assembly, I edited the pinion and used copy object to bring the 20 cutters into the pinion part file. I had hoped to use combine to then cut away the material where the cutters intersect with the pinion. This could be done by either combining the cutters into a single larger object, and then subtracting this from the pinion (the combining didn't work at all - WHY??). Or, individually subtracting each cutter form the pinion using combine: this also didn't work, as combine fails after a maximum of 4 combines.
Alternatively, in the assembly I edited the pinion, and drew a new sketch on the tangential face of the cutter, which gives me the profile of the cutter. I then drew a second sketch at right angles to, and through the centre of, the first sketch, and drew an arc of r=6mm from the tip of the cutter to use a a guide. So I then used Sweep to move the profile in the first sketch along the arc in the second. This worked once, but failed on the second (out of 20!!) cutter.
Can anyone see a way to get this to work, or even see a better way of solving the problem?
Some files are attached
Many thanks
Stephen
