Hi all,
Is there a way to turn off visibility for a thicken feature? I can suppress it, but I use the feature in constraints so I do not want to suppress it.
Thanks, Steven
Solved by CCarreiras. Go to Solution.
Hi!
You can set the Thicken feature as a new solid, then you can hide the solid.
Check it:
That is what I was missing. Thanks!! I had it as a new solid but forgot to go to the solid in the browser.
Thanks so much!!
Steven
