Hide Autocad lines in drawing
johan.degreef
Advisor Advisor
johan.degreef
I used an Autocad drawing (import) on my groundplane. Is there a way t o hide some of the lines (that are behind model geometry)?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Cadmanto
@johan.degreef
Does this inserted Autocad dwg not show up in the browser as something that gives you the ability to turn off the visibility on?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johan.degreef
Yes, per Autocad layer, but not as what should be hidden because of 3d model geometry.
johnsonshiue
Hi Johan,
This is unfortunately a limitation at the moment. I am not aware of a way to hide some lines. The only way is probably use a layer in the dwg file to manage it. You will need to edit the dwg file in AutoCAD to do that.
Many thanks!
Software Test Engineer
